Front defroster not blowing
150,000 MILES • 5.3L • 4WD
JOHN BARZAL
I've replaced the door actuator and tried re-calibrating, i.e. turning key on two notches, pressing auto on climate control, pulling fuses and restarting and still not working. What should I try next?
Dec 29, 2019 at 10:08 PM
  • 55,746 POSTS
If you remove the actuator and turn the system on can you see the actuators moving? Also when the actuator is out can you move the pivot manually to see if the blend door inside the plenum is working as well? this guide can help:
Dec 31, 2019 at 3:36 AM
