Front crankshaft seal leaking?
63,250 MILES • 6.2L • V8 • 2WD • AUTOMATIC
ADAMREPRO
The front seal on my crankshaft is leaking oil. I would like to have a repair estimate. I live in Orange County California, and my zip code is 92677. It would be great if you could also recommend a repair facility.
Thank you
Aug 21, 2025 at 7:40 AM
MECHTRIX
  • 590 POSTS
For that job it might be best to google it and look at theyre ratings and call around your area to see where the closest chevy dealer or any other shop is that will work on it ..also if you look for shops that work on chevys near you using google maps .. it will show all the ones nearest you on the map click them to get theyre websites along with theyre phone numbers its probably the best and fastest way to find a good shop near you ...good luck hope this helps
Aug 21, 2025 at 1:09 PM
  • 55,721 POSTS
I always liked Bednar Automotive.
Aug 22, 2025 at 2:06 AM
  • 55,721 POSTS
Sorry, Bedard Automotive
3601 E Miraloma Ave, Anaheim, CA 92806
I had good luck with these guys
Aug 22, 2025 at 6:29 AM
