Front coil spring/strut assembly
171,000 MILES • 3.0L • V6 • AWD • AUTOMATIC
DON FERREIRA
  • 5 POSTS
Hello, I am a retired auto collision repair tech but now money has become a huge problem. I need to know if I can safely replace one side of my coil/strut assembly at a time. I can afford to replace one side this month and the other side with alignment, next month. Can I do this safely? One side at a time?
Nov 3, 2016 at 8:26 AM
CARADIODOC
  • 34,413 POSTS
The strut is not involved with the alignment on your car. The coil spring is responsible for ride height, and that is related to alignment because it changes the suspension parts geometry, and therefore the motions the wheel goes through as the car goes up and down over bumps.
Be aware that handling and braking are compromised when anything is not equal on both sides of the car, so get the second strut replaced as soon as possible.
The new coil springs will restore ride height to manufacturer's specifications, so you may find the front end is in better alignment than it was before. Regardless, the alignment should be checked.
Nov 3, 2016 at 8:44 AM
DON FERREIRA
  • 5 POSTS
Thank you Caradiodoc, I really appreciate your prompt response. Thanks for the reassurance. I will certainly replace the other side ASAP. :)
Nov 3, 2016 at 8:54 AM
  • 55,682 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
Nov 7, 2016 at 1:11 AM
