Front climate control
150,000 MILES • 3.8L
CHRIS NEWCOMB
Strange issue. The front A/C does not work when it extremely hot outside. For example this morning it was in the low eighties and it was working just fine. However, yesterday and every day for the past month when it has been over nineties the front A/C does not work. The back works fine. Any suggestions on what I should look at replacing?
Jul 26, 2018 at 1:24 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
First you should check the fuses and front A/C relay before replacing anything. Make sure there is good connections and not melted. I have attached a relay test tutorial and the A/C relay location. Hope this helps and feel free to ask any questions if needed. Thanks for using 2CarPros.
Danny-
Jul 26, 2018 at 5:52 AM
