I completely re did the braking system, except the ABS Module. All new brake lines. No crimps in the lines. All new calipers front and back. New flex lines in front wheels to calipers. Replaced the front calipers again thinking there might be a defect. still have the same problem. Front brakes binding. Next step replaced the master cylinder. Same problem. Replaced the master cylinder again. Still the same problem. Truck has ABS. I'm wondering if the ABS Module is not releasing pressure?. Any ideas? Thanks!
Sep 22, 2014 at 4:57 AM
