Front brakes heat and lock up
170,000 MILES • V6 • 2WD • AUTOMATIC
ALVIN IGNACIO
Front brakes heat and lock up after 10 minutes of driving. ABS warning lights turns on.
Changed the front brake calipers, rotors, both front brake lines, rear drum brakes, rear brake cylinders, drums, and rear brake components still the problem persists.
Aug 12, 2019 at 4:32 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you are having trouble with the ABS system itself.Since the ABS light is flashing that means there is an ABS trouble code stored in your vehicles computer.First thing is to have the code(s)read. Most auto parts stores will check for free. If not auto parts stores have a tool loaner program and can rent you a scanner/code reader.Here is a tutorial showing what is involved:
Once this is performed get back to us with the code number(s) and then we can properly diagnose your vehicle.Hope this helps and thanks for using 2CarPros.
Danny-
Aug 12, 2019 at 6:11 AM
