Front brake rotor removal
200,000 MILES • 6 CYL • 4WD • MANUAL
YOGI BEAR
  • 7 POSTS
When you pull the hub off of the spindle does the hub separate from the rotor?
Dec 20, 2020 at 7:48 PM
  • 110,248 POSTS
Yes, they will come off together. Here are the directions specific to your vehicle. I'm adding them because based on the differential used, the axle could be different. The attached pics correlate with the directions.
____________________________________
1989 Ford Truck F 150 4WD Pickup L6-300 4.9L
Removal
Vehicle Brakes and Traction Control Disc Brake System Brake Rotor/Disc Service and Repair Procedures Brake Rotor/Disc Removal
REMOVAL
1. Raise the vehicle and install safety stands.
Lock Ring And Adjusting Nut Removal
Pic 1
2. Remove the locking hubs.
3. Remove the wheel lug nuts and the wheel and tire from the hub and rotor assembly.
4. For vehicles equipped with Dana model 44 front drive axle and manual hub lock, remove the adjusting nut with spanner locknut wrench. Apply inward pressure on the locknut wrench to disengage the adjusting nut locking splines and turn the nut counter-clockwise to loosen and remove the nut from the spindle.
For vehicles equipped Dana model 44 with automatic hub locks, Dana model 50 and model 60 front drive axles, remove the outer locknut, lock washer and inner locknut with spanner locknut wrench.
5. Remove the brake caliper and secure it to the frame to prevent damage to the brake hose. To prevent damage to the hose or the caliper, do not let the caliper hang only by the brake hose.
Hub, Disc And Outer Bearing Removal
Pic 2
6. Remove the hub and disc assembly. The outer wheel bearing cone and roller assembly will slide out as the hub is removed.
_________________
Apr 6, 2021 at 5:09 AM
YOGI BEAR
  • 7 POSTS
Thanks for the help. I have another question. Why does my right front brake lock up? I replaced the hose and bled that side. I drove it several miles before it started grabbing again. The pads were still like new.
  • 110,248 POSTS
Usually, heat is the cause. Chances are it is dragging a bit, getting hot, and then locking when you apply more pressure. The heat causes expansion.
I have to ask a favor. If possible, could you copy and paste this question to a new post. We are trying to keep the threads specific to one topic to help others. I hope you understand.
Here is the link to get you there fast:
Take care and I hope you had a good New Year!!!
