Front driver's side brake pads removal
95,000 MILES • V8 • AUTOMATIC
DYJY
I cannot get the front driver side brake pads off. Is there a trick to it?
Jun 13, 2020 at 3:01 AM
Good afternoon,
I attached the procedure for you to remove the caliper and the pads.
What is the issue? Can you upload a picture of the issue?
REMOVAL
1. Raise and support vehicle.
2. Remove front wheel and tire assemblies.
Retainer Clips And Anti-Rattle Springs
3. Remove caliper mounting bolts, retaining clips and anti-rattle springs.
4. Remove caliper by tilting it rearward and lifting up and off rotor.
Removing Outboard Brakeshoe
5. Remove outboard brake shoe from caliper. Use pry tool to remove shoe from caliper if flanges are tight.
Inboard Brakeshoe
6. Remove inboard brake shoe from caliper mounting adapter.
7. Support caliper, do not allow brake hose to support weight of caliper.
8. Remove 0-ring from caliper adapter.
INSTALLATION
1. Bottom pistons in caliper bore with C-clamp. Place an old brake shoe between a C-clamp and caliper piston.
2. Install inboard brake shoe in adapter.
3. Remove protective paper from noise suppression gasket on new outboard shoe.
4. Install outboard brake shoe in caliper. Remove any free play by bend shoe retaining flanges. Bend flanges until shoe has a light interference fit in caliper.
5. Lubricate slide surfaces of caliper mounting adapter and caliper with Mopar high temperature, or multi-mileage grease.
6. Install 0-ring in adapter, if removed.
7. Install caliper over rotor and into adapter. Do not displace or damage the piston dust boot when installing the caliper.
8. Install caliper retainer clips, anti-rattle springs and retaining bolts. Tighten bolts to 20 Nm (180 inch lbs.).
9. Install wheel and tire assemblies and lower vehicle.
10. Apply brakes several times to seat caliper pistons and brake shoes and obtain firm pedal.
11. Top off master cylinder fluid level.
Jun 13, 2020 at 4:41 AM
