front blower motor vibrates, and is loud
2003 VOLKSWAGEN EUROVAN
150,000 MILES
MRKEVIN
the blower in dash is loud and vibrates I was told the fan had a broken
blade or two. How easy to replace the assembly, I would assume I should replace the motor ass well
if I'm digging into it. I've read a couple things about glove boxes, but I have air bag.
Thank, Kevin
Dec 3, 2014 at 6:24 AM
  • 110,241 POSTS
The blower motor is under the dash and requires some work to access. If you are going to do it yourself, disconnect the battery at least 30 minutes before you begin working around the air bag. And yes, I would replace the motor too. Chances are the uneven weight from a broken fan blade damaged the motor's internal bearings.
Dec 3, 2014 at 9:33 PM
