Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Grand Prix
Drivetrain
Differential
Axle
Replace/Remove
Front axle replacement
2003 PONTIAC GRAND PRIX
125,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
GMACYELLOWSTONE
MEMBER
1 POST
Replacing left front axle. how do you depress the clip on the output shaft?
Jul 15, 2019 at 6:42 AM
Experienced Mechanic
Good afternoon,
The clip is not depressed for removal or installation.
You can use a large pry bar between the axle and the transmission to release the clip. It takes some pressure but it will release and slide out.
https://www.2carpros.com/articles/replace-cv-axle
Images (Click to enlarge)
Jul 15, 2019 at 6:49 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
