Front and rear main engine seals
120,000 MILES • 4 CYL • 4WD • AUTOMATIC
SCOTT DAVIES
Hi, just wondering is it in the procedure to change engine oil when you change front and rear main seals?
Nov 7, 2019 at 2:06 PM
  • 110,248 POSTS
Based on what you have done, dirt could have entered the engine. Therefore, I would recommend doing it. Also, when you review procedures, they are usually very specific to what is being done. In this case, they would have indicated the directions for seal replacement. It's unlikely that an oil change would have been mentioned.
Here is a link you may find helpful. It explains in general how it's done.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
I hope this helps. Let me know if you have other questions.
Nov 28, 2020 at 12:46 PM
