ABS light on
80,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
BRYCE CLINE
  • 32 POSTS
I would assume most modern cars come with ABS brakes in the front at least, but I’m not seeing any wires at the hub, but the front end has been torn apart. I have the car listed above 3i model. Is there a way to find out if this car came with ABS?
May 2, 2020 at 2:40 PM
Good morning,
It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
and
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Please run down these guides and report back. If you have a yellow light on the dash that says ABS when you turn the key to on, then you have ABS option. If you have ABS, I attached a picture of the location for the control unit.
May 2, 2020 at 10:16 PM
BRYCE CLINE
  • 32 POSTS
Thank you, I thought most modern or all had ABS, both Mazda 3s I have don't have it.
May 16, 2020 at 8:29 AM
You are welcome.
Always glad to help.
May 16, 2020 at 12:04 PM
