A/C blower motor only works at higher speeds ?
239,778 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
MATTIIE_B
Front A/C blower motor only works at higher speeds
Jun 10, 2020 at 1:03 PM
Good morning,
Do you have a voltmeter or test light to do some checks for the blower motor system?
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
https://www.2carpros.com/articles/replace-heater-core
I attached a wire diagram and need to see if the correct voltages are present for proper operation.
Jun 10, 2020 at 7:17 PM
