What is the firing order?
100,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
PACIFICISLANDER
  • 239 POSTS
Need to know the firing order to the coil packs from the cylinder head. Also, where is the camshaft position sensor located?
Sep 13, 2022 at 4:57 PM
BORIS K
  • 836 POSTS
This engine only has one coil which feeds the distributor. If your vehicle has two ignition coils, then you are working on a 1997 model.
The firing order is the same, 1-3-4-2 with cylinder 1 being nearest to the timing belt.
See image one below.
On the vehicle using two coils the left coil fires cylinder 1+4 and the right coil, further back, fires cylinders 2+3. The coils are marked.
How to replace double coils:
https://youtu.be/78R8dEhnE2c
If the engine has a distributor, then the camshaft position sensor is located inside the distributor.
The later model has the camshaft position sensor located near the from camshaft pulley.
See image 2+3 below.
Cheers, Boris
Sep 14, 2022 at 2:18 AM
