What is the Freon capacity for this vehicle?
206,000 MILES • 5.7L • 4WD
LEAD FOOT
freon capacity with dual air. Several sites say 3.5 lbs and then some say 4 lbs. I really would like to know what is the proper capacity according to GM specs. The sticker is missing.
Jul 1, 2021 at 1:43 AM
BORIS K
  • 836 POSTS
According to Mitchell 56 ounces (3.5lb) of 134a with rear air con.
Please let us know how you get along.
Cheers, Boris
Jul 1, 2021 at 2:01 AM
Good evening,
The capacity is 3.5 pounds as the previous tech stated.
Make sure you recover the system and evacuate the system for at least 45 minutes, then add 1 ounce of oil and charge the system to 3.5 pounds.
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
If the system is low, you should check for a leak in the system as well. I attached a guide for you for the procedure.
https://www.2carpros.com/articles/air-conditioner-leak-detection
Jul 1, 2021 at 9:55 AM
