freeze plugs location needed
180,000 MILES • V6
KATHY NEAL
where are they located and how many are there?
Sep 14, 2021 at 11:24 AM
The 3.0L and 4.0L both have two freeze plugs on each side of the block just under the heads. Then each head has one in the front and rear of each one.
Not sure why you are looking for these but the most common reason is you have a leak. If that is the case, I would suggest pressure testing the system just to confirm where the leak is coming from.
https://www.2carpros.com/articles/radiator-pressure-test
Below are pictures of each side of the 3.0L but the 4.0L is pretty much identical.
Let us know if you have other questions. Thanks
Sep 15, 2021 at 12:23 PM
KATHY NEAL
thank you your a great help much appreciated.
Sep 15, 2021 at 1:45 PM
You are welcome.
Thanks for using 2CarPros. Please come back in the future.
If you care to, please leave a review at this site. Clearly it is not necessary but it will help spread the word.
https://www.sitejabber.com/reviews/2carpros.com
Thanks again.
Sep 16, 2021 at 1:35 AM
