Freeze plugs
240,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
JOEL SNYDER
I have leak at rear of engine and wanted to know what size the freeze plugs are. Parts store only shows 4 for side of engine but doesn't show plugs for rear of engine. Leaks very bad
Jan 7, 2016 at 5:15 AM
HMAC300
  • 48,601 POSTS
pressure check it first may not have plugs in back. they don't show us freeze plugs
Jan 7, 2016 at 8:04 AM
JOEL SNYDER
Water is leaking too bad its either bad freeze plug or block is cracked it is leaking between transmission and engine it even leaks while filling.
Jan 7, 2016 at 8:18 AM
HMAC300
  • 48,601 POSTS
won't have any pics that so I guess you'll have to go by whatparts guy said besides you didn't give engine size
Jan 7, 2016 at 9:09 AM
JOEL SNYDER
98 jeep 4.0 i-6
Jan 7, 2016 at 9:19 AM
JOEL SNYDER
Sorry I had put it on everything else I had filled out
Jan 7, 2016 at 9:20 AM
HMAC300
  • 48,601 POSTS
engine size doesn't come through on our new system . still pressure check could be head gasket
Jan 7, 2016 at 10:47 PM
