If not, then I attached below the entire freeze plug kit for the block from Rock Auto. For $12.00, you have them all. You will need to punch them inside the block and use a pair of pliers to remove them.
Image (Click to enlarge)
Feb 21, 2021 at 6:24 PM
REGALDAVE
MEMBER
Thanks you for the reply. Yes, it was behind the block. Previous owners had replaced them all but this one didn't stay put,. so I got was able to buy the truck cheap for a first vehicle for my daughter.
