Need to replace both front freeze plugs on both sides. Do I need to lift the engine?
Aug 17, 2018 at 9:36 AM
CAR REPAIR CONTRIBUTOR
Good afternoon.
Yes, it would make it a lot easier for access if you lifted it off the motor mounts.
I would suggest doing all of them if you can. If one or two has failed the others are close from behind. They rot from the inside out.
Aug 17, 2018 at 3:55 PM
