How to replace the rear passenger side freeze plug?
170,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
58RIVERRAT
Rear passenger side freeze plug replacement instructions needed.
Jan 19, 2023 at 11:39 AM
  • 55,740 POSTS
This depends on which one you are talking about, you may need to lift the engine on one side and use a long extension to knock the freeze plug inward and then use large pair of pliers to remove the old soft plug, this tool is used to reinstall the new freeze plug.
https://amzn.to/3J3iNaH
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Jan 20, 2023 at 2:38 AM
58RIVERRAT
The rear passenger side.
Jan 20, 2023 at 7:38 AM
  • 55,740 POSTS
If you can upload picture of the job I can help walk you through it. There is no straightforward way to do freeze plugs it is by a per case operation.
Jan 21, 2023 at 2:02 AM
