Freeze plug
70 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
WALKER 53
Freeze jumped need to know what size I need to fix it.
Jun 12, 2018 at 3:51 AM
STEVE W.
  • 15,409 POSTS
If you are saying that a freeze plug failed the size depends on which one it is. There are multiple sizes as well as threaded plugs and simple cups. 3/4 inch, 1.5 inch, 29/64" and 53/64 inch. If it failed due to corrosion then I would likely replace all of them as the rest are probably in no better condition.
Jun 12, 2018 at 8:50 AM
WALKER 53
My 2006 Nissan Altima running hot one of the radiator fans not working would this cause it to run hot?
Jun 12, 2018 at 9:34 AM
RENEE L
  • 1,260 POSTS
Hello WALKER 53,
Please post your new question here:
As you are asking about a different issue with a different vehicle.
Thank you,
Renee
Jun 12, 2018 at 10:15 AM
