Freeze plug?
140,000 MILES • AUTOMATIC
NESSAKINS93
How to get to the upper freeze plug on the drivers side? What needs to come off
Dec 26, 2025 at 5:47 AM
  • 55,694 POSTS
Yep, these can be tricky and there is no "one way" of doing thins job, there is only, "technique" you must remove anything you can to get a better angle on it so you can do the work, even remove the engine mount if needed and raise the engine on one side, if you add a video in you response of the problem I can help more, in the meantime here is a video to show you the tool you will need.
https://www.youtube.com/watch?v=2Qf7LT3LAX8&pp=0gcJCU0KAYcqIYzv
Let me know how it goes.
Dec 26, 2025 at 9:38 AM
