Freeze plug
25,000 MILES • 5.0L • V6
TAMARA PAYNE
Leaking water in back of engine.
Apr 20, 2018 at 1:07 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Freeze plugs in the back of the engine can be hidden by the transmission. You should be sure where the coolant is leaking from before having to remove the transmission in order to either look closer or even replace any freeze plugs. I suggest you either purchase, rent or borrow and cooling system pressure tester and pump the cooling system up to 15 psi or so and look again cause the leak will be a lot bigger and easier to see.
Apr 20, 2018 at 11:56 PM
RENEE L
  • 1,260 POSTS
Hello TAMARA PAYNE,
I am sending you a link to a helpful and informative article from this site. This article features a step by step guide, pictures and a video on how to pressure test a cooling system.
https://www.2carpros.com/articles/radiator-pressure-test
Thank you for visiting 2CarPros.
All the best,
Renee
Admin
Apr 21, 2018 at 6:48 AM
