Fowling # 8 plug
MARY ANN HAMBY
  • 2000 DODGE RAM
  • 0.5L
  • V8
  • 4WD
  • 175,000 MILES
There was spark, knocking and started missing and it had been using water and oil. It did not smoke or leak. It ran good until then. I put 10,000 miles on since purchased not run hard. When it started missing I changed the plugs, wires and cap. It keeps fowling #8 plug as soon as I can put one in. I tried fowler that did not work either
what is the problem?
Tuesday, June 21st, 2016 AT 1:45 PM
  • 109,872 POSTS
When you say it is using water, I assume you mean coolant. Check for white smoke from the exhaust as well as coolant mixing with the engine oil. If either of these things are found, then there is most likely a head gasket issue. If nothing is found, check compression in cylinder 8 and make sure you don't have a stuck injector. However, since it is using coolant, that leads me to believe there is a head gasket issue.
Thursday, June 23rd, 2016 AT 6:45 PM
