Four-wheel Drive Selector Control is not engaging the four-wheel drive. The selector control knob is on Auto. When I move the selector control it moves but the lights for 2L,4H or 4L do not light up and engage. I can move the selector control all the way to the left to neutral and all the lights light up including the neutral light. When I first turn on the truck all the lights on the selector control light up and go off with the exception of the Auto light. I removed the front axle actuator and it activated when I tested it with 12 volts directly from the battery. I also tried changing the transfer case module with a used one and no change. I also replaced the transfer case motor and it made no difference so i removed it and returned it. Vehicle ID no. 1GTEK14J08Z302940 Transmission is a 4L60E engine 5.3L
Hope you can help, thank you.
Jun 27, 2022 at 1:54 PM
