four trouble codes: P0170, P2251, P2195, P2414
185,000 MILES
ELDOM72
  • 6 POSTS
When I started my car this morning, the CEL came on, so I took it to an AutoZone and they pulled out these 4 codes. P0170, P2251, P2195, P2414. What can be causing all these 4 codes altogether? Thanks for the help.
Oct 29, 2013 at 10:52 AM
HMAC300
  • 48,601 POSTS
check battery condition including load test then check fuel pressure, it may be an O2 sesor but fuel pressure low will cause a couple of those. should be 49.8 psi. it may need an adapter to check this or have a pro do it.
Oct 29, 2013 at 11:30 PM
