Where is the fuel pump relay located?
170,000 MILES • 2.5L • 4 CYL • 4WD • MANUAL
MATTHEW PENNINGTON
Will turn over but will not crank. Where is the fuel pump relay located on the vehicle listed above?
Feb 22, 2021 at 12:46 AM
  • 110,251 POSTS
If I recall, the relay is located under the dash on the driver's side. I attached the only pic I was able to find. Take a look at it and let me know if it helps.
I'm not sure what you are dealing with. If you have other questions, let me know. Also, here is a link that shows how to test a relay:
I hope this helps.
Take care and God Bless,
Feb 22, 2021 at 9:46 AM
