Someone put oil and antifreeze in the master cylinder
1999 BUICK SKYLARK
145,000 MILES • 2.8L • 4 CYL • 2WD • AUTOMATIC
DANIEL LEE
Should I change the master cylinder and both back wheel cylinders and the two front calipers and blow out the brake lines to fix this? A line broke in the front and the pedal went to the floor. Now I can’t get a firm pedal. It won’t pump up to bleed out the fluid. Also there is a weird substance in the fluid that comes out when I open the bleeders.
Jun 1, 2021 at 1:58 PM
Good morning,
Yes, anything with rubber has to be replaced. The petroleum in the fluid ruins the rubber seals and will cause total brake failure.
https://www.2carpros.com/articles/brake-caliper-replacement
https://www.2carpros.com/articles/how-to-replace-a-brake-master-cylinder
https://www.2carpros.com/articles/how-to-replace-a-wheel-cylinder
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
You should be good after replacing all those parts. Make sure you get all the old fluid out before installing the new parts. If you do not, it will ruin the new parts as well.
I will give you procedures but can you confirm it is a 1999 and not an 1989. 1989 that had the 2.8 engine.
Jun 1, 2021 at 6:57 PM
