1992 Mercury Sable Gear Slip
SMCMLLN
Okay. First i have a 1992 Mercury Sable with 240000 miles on it. the car just recently started to do this. I would go to take off. it would drive fine. But maybe after a sharp turn, or somewhat of a hard acceleration, going from first to second seems like it slips. it would grab. then after that, *normal driving* going from first to second would be fine. But it would take second to go to third about 3000 rpms. after that it will go to third and directly to forth. and when this all started happening, The tourque converter lock up quit working. The fluid was a little low, but I have added some and got it back to to the top. and yet it still does that. I know that it could be the trans getting ready to go out, but I don't have the money to fork out for a new tranny *or a junk yard tranny* If anyone has any idea, please let me know. it owul be greatly appreciaited.
Mar 23, 2006 at 2:20 PM
RAYHUT
  • 134 POSTS
i had the same problem but i fixed it.go to your nearest auto store and by some transmission leak flued it cleans it seals and it will solve your problem. it did mine and it shifts great now for 2 weeks haven't had a problen yet. knock on wood.the stuff is call T34 Transmission stop leak.great stuff.
Mar 24, 2006 at 11:36 PM
Suggested Repair
Try T34 Transmission Stop Leak, which the expert said cleans and seals the transmission and restored normal shifting in a similar case.
Conversation Summary
The owner of a 1992 Mercury Sable with about 240,000 miles reported intermittent first-to-second slip after sharp turns or hard acceleration, a delayed second-to-third shift around 3000 rpm, and loss of torque converter lockup. Fluid was slightly low and was topped off, but the symptoms continued. An expert said the same issue was fixed with T34 Transmission Stop Leak and that shifting remained normal for two weeks.
