1964 Ford F-600 No Movement in Gear
AKMOUNTAINMAN
1964 Ford F-600, 4 speed manual transmission with hi-lo rear end. Motor was running, driving up a hill and then we stopped moving, motor still running fine, can put standard transmission in gear and let out clutch, still no movement, while coasting backward down hill I did see that the driveshaft from the rear end was spinning. I assume a tranny problem, but any ideas of where to start?
May 7, 2007 at 1:41 PM
MERLIN2021
  • 17,250 POSTS
When it stopped going forward...did it roll or lock up? When you clutch it do the gears grind? if not and the clutch seems to work normally...you may have snapped the tranny output shaft...
May 8, 2007 at 2:21 AM
AKMOUNTAINMAN
yes it rolls, regardless if i am in gear or not, i couldn't see any outward damage to the visible driveshaft (rearwrd of tranny) and the driveshaft does spin while the rear tires are rolling (so i ruled out rear-end problems) could it be something between the engine and tranny? clutch still works, can go into all gears but to no effect of rolling, or hampering motor, no grinding when gearshifting without clutch
May 8, 2007 at 12:14 PM
Suggested Repair
With the clutch working, no gear grind, and the truck rolling freely while the rear driveshaft still turns with the wheels, inspect the transmission output shaft for a break and repair or replace it as needed.
Conversation Summary
A 1964 Ford F-600 with a 4-speed manual lost forward drive while the engine kept running. It rolls in or out of gear, shifts into all gears without grinding, and the rear driveshaft spins with the tires, so the owner ruled out the rear end. The expert said a normally working clutch and no grinding point to a snapped transmission output shaft.
