1996 Ford Windstar Lack of Power
hy guys, I tried asking a question some time ago and unfortionatly didnt get any response.I hope i have better luck this time. Anyway, what i have is a 1996 windstar,3.8 liter with 122.000 kms. The truck broke down on me going through the hills of tennessee, running perfect until the hills came along. The first sign of trouble was lack of power going up hills, it felt like going from one gear to another. Then i noticed the oil light on. Oil was ok and oil pump was ok, in the end it cost me $600.00 for a small gear at the end of what i thought was the distributer shaft. I was sent on my way and told good luck making it back to toronto canada. Well that was one month ago and i did make it home, but now im starting to fell the same kind of thing i felt just before the break down in tennessee. Could the tranny be causing my engine problems, any ideas would help
Apr 27, 2007 at 4:45 AM
Tranny problems and Fords...mostly new wires and plugs clear these concerns up. Check fuel pump pressure while your at it! If the oil light is on again, Get a pressure test so you don't wreck the motor...
Apr 28, 2007 at 3:17 PM
Suggested Repair
Replace the spark plugs and ignition wires, and check fuel pump pressure. If the oil light comes on again, have an oil pressure test done before further driving to avoid engine damage.
Conversation Summary
The owner of a 1996 Ford Windstar with a 3.8L engine reported loss of power on hills, a sensation like gear changes, and an oil light. Oil level and the oil pump were fine, and a small gear at the end of what was thought to be the distributor shaft was replaced for $600. The same symptoms are returning, and the owner wonders if the transmission is causing engine problems. The expert said Ford transmission-like concerns are often cleared by new wires and plugs, advised checking fuel pump pressure, and recommended an oil pressure test if the oil light returns.
