Tranmission/engine oil problem
ANOINTEDMOG
I have a 1995 Ford Aeorstar 6 cylinder engine with 199,000 miles the transmission is leaking and I cannot see where it is leaking. There is no fluid on the ground but there is fluid on the front bumper. Can you tell me what I might check to find the leak. Secondly, The engine oil level is rising after I change the oil. I am not losing antifreeze and there is no foam in the oil when I check it. When I change the oil it does not seem to be much thinner than normal. What could be causing this problem? Please help!
Terry Milliner
Nov 23, 2006 at 9:55 AM
TWCCO
It sounds like your engine is filing up with trany fluid.
Nov 25, 2006 at 6:46 PM
BRUCE HUNT
  • 3,754 POSTS
Tranny leak sounds like the cooling system as the tranny fluid goes through the radiator.
Need more info on the oil level rise.
Nov 26, 2006 at 2:37 AM
