My car doens't work!!
MOMMYOF3
When I first get into my car and start it up then put it into gear it start to almost accelrate on it's own. Then if i give some gas it will start to lunge (not really sure if that is a good way to say it :? ). Then if I go for a little bit it wiill run fine, But when I slow down or come to a stop it will die on me. I travel alot and I also have 3 kids. This isn't something that is very convienent if you know what I mean... :) So can you please tell me what is wrong. I was also given a code. It is P1336.
Thank you for your time,
Heather[/code]
Nov 15, 2006 at 6:43 AM
BOOTDOG
  • 665 POSTS
what is the make, model and year to start
Nov 15, 2006 at 9:31 AM
RANGERMANIAC
  • 20 POSTS
depending on your vehicle this is what is wrong probably your crankshaft position sensor is bad
P1336 Crankshaft Speed Fluctuation Sensor Intermittant Interruption (Acura)
P1336 CKP and/or CMP Input Signal to PCM Concerns (Ford)
P1336 Crankshaft Position System Variation Not Learned (GM)
P1336 Crankshaft Position Sensor (CKPS) (Nissan, Infiniti)
Nov 16, 2006 at 11:27 PM
