1996 Ford Aerostar Cylinder 2 Misfire
PLUDGE55
check engen light comes on and blinks I read the code and it said misfire in cilender 2 It is a 1996 ford arostar 3.0 i changed the pluges and wiers but still comes up the same what could it be?
Feb 24, 2007 at 4:10 AM
NOS
  • 320 POSTS
run a compression check on that cyclinder. did the plug that you took out of it look ok or did it have a green tint to it? if so you may have a bad headgasket problem. the( coil )would be a good place to start. and less expencive. 8)NOS
Feb 24, 2007 at 6:26 AM
Suggested Repair
Perform a compression check on cylinder 2. Inspect the removed spark plug for a green tint, which can indicate a head gasket problem. Also check the ignition coil, which is a less expensive starting point.
Conversation Summary
The owner of a 1996 Ford Aerostar 3.0 reported a blinking check engine light and a cylinder 2 misfire code that continued after replacing the spark plugs and wires. The expert recommended a compression test on that cylinder, checking the old plug for a green tint that may point to a head gasket issue, and starting with the coil because it is less expensive.
