1999 Ford Windstar
When changing the front temperature on the heat/AC controls on the dash panel, there has been a clicking sound coming from the dash and heat is not produced. The AC works fine, and there is generally no clicking noise if the controls are set for cool. I do have rear heating that does work, and there is no clicking generated when the rear temp controls are moved.
Is there a switch, fuse, or thermostat that needs to be replaced or is this a bigger problem?
Apr 9, 2007 at 2:42 AM
