2001 Windstar with front and back heaters. Plenty of fluid and back is throwing heat. Front suddenly quit giving any heat. Initially after this occurred I was running only front heat. When I turned the back heat on the front heat began working. They both worked for about a week and then the front quit again. I turned the back heat on and got heat there but the front still does not give heat. This is also true with the defrosting. All of the fans work fine.
Oct 18, 2007 at 10:11 AM
