HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Windstar
Engine
Symptoms
Stall While Driving
Ford windstar2002 124000k 3.8L stalls while driving
RONALD333
MEMBER
2002 FORD WINDSTAR
Hi, yes I am up for some testing. I am at my wits end and really appreciate your concern. Thanks
Friday, November 16th, 2007 AT 12:11 PM
GAIL661968
MEMBER
I had the same problem and it was a hole in the pvc valve very easy fix it is right on top of valve cover rear toward fire wall
SPONSORED LINKS
Thursday, November 22nd, 2007 AT 8:47 AM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
Stalls While Driving
Can You Tell Me Where The Pcm Power Relay Is Located.
Asked by
ronald333
2002
FORD WINDSTAR
VIDEO
How to Read Codes
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
2002 Ford Windstar High Idle Then Dies
My 2002 Winstar Idles At 3500 Rpms Then Idles Down To Around 1100 Rpms Then Dies, When I Restart It, It High Idles At 3500 Rpms Then Idles...
Asked by
Maxelltheone
3 IMAGES
2002
FORD WINDSTAR
2002 Ford Windstar Dies On Hot Days
Recently Had Alternator Replaced. Had Fluids/filters Checked-replaced In April. Noticed This Some Last Summer, But When Windstar Is...
Asked by
C.Robinson2
2002
FORD WINDSTAR
Engine Will Crank But Not Idle
Have Replaced Fuel Pump Camshaft Sensor Crankshaft Sensor Plugs Iat Sensor Now Plugs Soaked With Oil And Will Hardly Start
Asked by
cindy136
2000
FORD WINDSTAR
Engine Shuts Down When It Is Hot And Humid Out
The Engine Shuts Down And Will Not Restart After Driving Thirty To Sixty Minutes In Hot Humid Weather. There Are No Error Codes And It Will...
Asked by
sklopp
1 ANSWER
2 IMAGES
2000
FORD WINDSTAR
VIEW MORE
SPONSORED LINKS
Check Engine Light Safe to Drive?
Code Read Retrieval/Clear Scion
Code Read Retrieval/Clear Chevrolet
Online car repair manuals
