electrical problems with dashboard
JJMJBOLSON
My 2001 ford windstar has a problem. Mileage 90000,
3.8 v6.
Radio, wipers, turn signals, instrument panel, power windows and climate control all dead when car is running. However when car is not running and key is
turned back towards driver to other position most of
the stuff works. What could be wrong?
May 25, 2007 at 12:32 PM
RUDPRO
  • 224 POSTS
What works in the accessory position that doesn't work in the run position? Also, did you check the fuses?
May 25, 2007 at 5:00 PM
RUDPRO
  • 224 POSTS
One more thing, does the radio or anything come on when the engine is running and you shift to neutral or reverse?
May 25, 2007 at 5:05 PM
