sounds like starter.
Feb 13, 2006 at 4:24 PM
Check battery, starter, and alternator wires and connections for looseness, worn insulation, or corrosion. Inspect the serpentine belt for stretch or cracks and confirm the tensioner applies good tension and its pulley turns freely. Have the battery, alternator, and starter tested.
The original post was removed; the remaining note suggested a starter problem. The expert advised checking both the charging and starting systems for intermittent starting issues, including battery, starter, and alternator connections, the serpentine belt and tensioner, and free testing of the battery, alternator, and starter.
