2002 Ford Mustang P0340 Cam Sensor
SUPERBEEF1000
  • 6 POSTS
i have a 2002 ford mutang gt with the 4.6 sohc
and the it is now giving me 2 codes p1000 and p0340
the first one means testing not compleet the second is a camshaft position sensor circut fault i changed the sensor and reset the computer and the check engine lite came rite back on with the sam problem the car is rumbling or haveing small back fires through the intake and exuast sometimes not starting when cranked then it is loosing power and chuging while driving can some one help? :?
Jan 25, 2007 at 4:31 AM
INDYUKE
  • 416 POSTS
Have you checked the wiring in between the camshaft sensor and the computer to see if it has been comprimised? Let us know.
Jan 25, 2007 at 1:26 PM
SUPERBEEF1000
  • 6 POSTS
yeh i have done the visual inspection and wiggled all the wires i could find and still nothing
Jan 25, 2007 at 4:14 PM
INDYUKE
  • 416 POSTS
Are you able to plug a scan tool into the cars computer and see if you can get a data stream from the sensor? It might not be picking up a signal.
Jan 26, 2007 at 11:52 AM
SUPERBEEF1000
  • 6 POSTS
no i dont have that type of equipment just a superchips tunner it only gives me the codes
?? do you think if my altinator was shorting out it could be causing this problem ??? i am seing that i have a bearing or somthing going out in the altinator
Jan 26, 2007 at 1:58 PM
INDYUKE
  • 416 POSTS
I don't think the alternator bearings going bad would cause the problem you describe.
I would somehow double check to see if the sensor is communicating with the computer effectively. Sometimes a position sensor (often wheel speed sensors for ABS) won't be positioned just right or close enough to pick up a signal.
Jan 28, 2007 at 9:27 AM
SUPERBEEF1000
  • 6 POSTS
well i tested the wires with a multi tester after replacing the sensor and i have dead wires , so signal going to or from the sensor the car is starting to idal realy bad like the iac is going out now i wonder if i got a bad computer
Jan 28, 2007 at 10:19 AM
TAURUSWHEEL
  • 718 POSTS
Did you use a factory service manual for the procedure to test the circuits??? Ford pcm units are extremely reliable, failures are not common. Of course following the steps for diagnosing the issue sometimes results in the determination that it is the pcm, not often though... don't be spending needless $$$, take it to a reliable shop versed in diagnostics, if it happens to be the Ford dealer, so be it
Jan 28, 2007 at 3:20 PM
SUPERBEEF1000
  • 6 POSTS
yeh i will be taking it to ford some time this week if i geta chance $120 for the scan
i will be sure to post the results
thanks for you help in any case
Jan 28, 2007 at 11:58 PM
Suggested Repair
Have the camshaft position sensor circuit diagnosed with a factory service procedure and a scan tool that can read live data. No signal after sensor replacement points to wiring or connector problems rather than the sensor or a failed PCM. Alternator bearing noise is unlikely related. A shop experienced with Ford diagnostics is recommended before replacing the computer.
Conversation Summary
A 2002 Ford Mustang GT with the 4.6 SOHC set codes P1000 and P0340, with rumbling, intake and exhaust backfires, hard starting, power loss, and chugging. Replacing the camshaft position sensor did not clear the fault. Visual wire checks found nothing, but a multimeter test showed no signal on the sensor wires. Experts said a failing alternator bearing was unlikely to cause this, advised confirming sensor communication and following factory circuit tests, and noted that Ford PCMs rarely fail. The owner planned a dealer diagnostic scan.
