Check Engine Light
TWMATT2003
I have a 1998 Ford Windstar and the check engine light is staying on. What is the problem? Sometime it seems to have a loss of power and then all at once it just takes off like normal. Is this related or another problem?
Jan 18, 2006 at 8:40 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Provide any existing scan results and clarify when the reported power loss occurred. No cause has been established in the thread.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
2CARPRO JACK
  • 11,533 POSTS
Need to have the computer scanned
Jan 18, 2006 at 8:46 AM
DOUG WARREN
take it to Auto zone (if you have one in your area) and they will scan it for free..Then you will have to decide where to go from there depending on the code. With out know the code it is hard to diagnois.
Jan 25, 2006 at 6:22 AM
Discussion summary
Check Engine Light
The owner of a 1998 Ford Windstar reported a check-engine light that stayed on and occasional loss of power followed by a return to normal operation. Replies requested diagnostic codes, but the owner supplied no scan results.
Reported outcome: No diagnosis, completed repair or resolution was reported.
The thread does not establish whether the warning light and power loss share a cause. Replies requested more information rather than reporting a confirmed fault.
Read the original discussion
