this is a problem you will need to get under the hood and isolate , check all spark plug wires for arcing ,(white spots , or you can do a wet test at night with a spray mister with water , start the car and hose down the wires and see if you can see any arcing , and go from there
Mar 10, 2007 at 1:51 AM
