I have a 2001 Ford Windstar with 72k miles and a 3.8 v-6. When I turn on the AC or heat and attempt to route the air through the front facing vents, the air will only come out the defroster vents. The AC and heat are working fine but the air will not divert out of the front facing vents. We recently had a manifold gasket replaced - is it possible that this work could have caused the venting problem?
Jun 5, 2007 at 2:29 AM
