98 ford windstar not shifting from 1st gear
AMERIEAGLE18
I recently obtained a 1998 ford winstar GL with a 3.8 litre V6 AX4S transmission. 119k miles Motor runs great but the Transmission will not shift from 1st gear at all. I even tried to manually shift from 1st instead of Drive and still wont work. I read more into it and some causes are the Transmisson Control Solenoid or Vehicle speed sensor. What are some things to look for before replacing any of these items? like signs of wear? maybe some troubleshooting ideas, if any? If perhaps it could be the V.S.S. wouldnt my speedometer not be working? currently it works.
Any information will be greatly appreciated.
Thanks so much!
-Josiah D. Gerhardt
May 5, 2007 at 3:17 AM
MERLIN2021
  • 17,250 POSTS
Have you looked at the fluid? any burnt smell or brown color? I would if the fluid is ok check the control mod and the pump...
May 6, 2007 at 12:59 AM
AMERIEAGLE18
fluid is very clean. what do you mean when you say pump? what are you refering to?
Thanks
-Josiah
May 6, 2007 at 1:40 AM
