Starter relay
131,000 MILES • 6 CYL • 2WD • AUTOMATIC
FIGHTINGBEE
I disconnected the battery to clean it, after I reconnected the battery, I turned the key and it just clicked. I have lights and the bell dings when I insert the key.
I was told it might be a starter relay. The cables come from the engine to a fuse box on the driver side by the air filter.
Nov 15, 2009 at 3:21 AM
  • 55,688 POSTS
It sounds like the connection is still dirty or the battery is dead, here are a couple of guides that will help you get the problem fixed.
Please let us know happens so it will help others.
Best, Ken
Feb 22, 2017 at 7:39 AM
GREG MARION
removal of starter on a 1998 windstar van 3.8 motor
Jun 18, 2019 at 11:42 AM (Merged)
  • 75,988 POSTS
REMOVAL
WARNING: WHEN SERVICING STARTER MOTOR OR PERFORMING ANY MAINTENANCE IN THE AREA OF THE STARTER MOTOR, NOTE THE HEAVY GAUGE INPUT LEAD CONNECTED TO THE STARTER SOLENOID IS HOT AT ALL TIMES. MAKE SURE THE PROTECTIVE CAP IS INSTALLED OVER THE TERMINAL AND IS REPLACED AFTER SERVICE.
Disconnect battery ground cable.
Raise the vehicle on a hoist.
Disconnect starter cable and push-on connector from starter solenoid.
CAUTION: When disconnecting hardshell connector at S terminal, grasp the plastic shell and pull off. Do not pull on wire. Be careful to pull straight off to prevent damage to the connector and S terminal. If any part of the connection is damaged, replace the damaged components.
Remove upper bolt.
Remove lower bolt and starter motor.
INSTALLATION
Position starter motor to engine and install upper and lower bolts finger-tight.
Tighten the upper mounting bolt to 20-27 N.m (15-20 lb-ft).
Tighten the lower mounting bolt to 20-27 N.m (15-20 lb-ft).
Connect starter solenoid connector. Be careful to push straight on and make sure connector locks in position with a notable click or detent.
Install starter cable nut to starter solenoid B-terminal. Tighten to 9-14 N.m (80-123 lb-in).
Replace red starter solenoid safety cap.
Lower vehicle to floor.
Connect battery ground cable.
