2003 Ford Windstar power steering noise
10,000 MILES • 6 CYL • FWD • AUTOMATIC
JPELLMAN
The vehicle produces a noticeable dragging motor sound (you turn the wheel and the sound indicates a drag on the power steering pump). More noticeable when parking the vehicle or sitting in traffic. The sound level gets higher, after the vehicle has been driven some distance. No indication of a problem through the steering wheel.
Are you supposed to hear the power steering pump when driving this vehilcle in a parking lot or sitting in traffic?
Apr 21, 2010 at 5:59 AM
  • 110,246 POSTS
The PS pumps in these vehicles have a history of making noies. It isn't uncommon. It is louder when moving slowly or stopped because the pump has to work harder to turn the wheels. Try to have it serviced. It may help, but I doubt it will completely fix the problem. NOTE: From my experience, aftermarket pumps and remanufacturered pumps make the same noise. Therefore, if you plan to replace it, spend the extra money and get a factory pump and have the rack and pinion and lines flushed properly.
May 12, 2010 at 6:34 AM
