2003 Ford Windstar OBDII
60,000 MILES • 6 CYL • FWD • AUTOMATIC
GATEKEEPER
  • 6 POSTS
hi guys, this probably has nothing to do with electrical, but here goes, i have a 2003 windstar sport, and i also have an engine lite and door ajar lite on plus i have a obd scan tool, the problem is that i can`t find the plug for the tool, i looked high and low and i can`t find it, i know it shouldn`t be that hard to find, i`m thinking someone may have removed it, is that possible? maybe i`m just not looking in the right place so i`m hoping you guys can help with that, any ideas where the hell it is....thanks guys.
Apr 21, 2009 at 1:06 PM
DAVE H
  • 13,383 POSTS
Data Link Connector....Below dash, on left of steering column. See Fig. 2
https://images.2carpros.com/forum/automotive_pictures/266999_dlc_3.jpg
Apr 21, 2009 at 1:35 PM
GATEKEEPER
  • 6 POSTS
thanks for the image guys, but is the connector easy to access or do i have to remove half the dash :)
Apr 22, 2009 at 12:41 AM
DAVE H
  • 13,383 POSTS
No ... you can access the DLC from underneath !!
Apr 22, 2009 at 10:29 AM
GATEKEEPER
  • 6 POSTS
hey guys, sorry for all the replies but i did as you said, i got my flashlite and crawled up under the dash as far as i could and no go, i still can`t find the thing, i know what it looks like and theres nothing around there that even looks like it, i guess i have the odd ford that they forgot to put one in :) i have one more question for you, where can i find the keypad entry code, its not in the glovebox and i don`t have a manual, i was told it may be on the computer but guess what....i don`t know where that is either.....thanks a million guys, i tried to give you good feedback but it wouldn`t let me.
Apr 22, 2009 at 12:51 PM
DAVE H
  • 13,383 POSTS
POWERTRAIN CONTROL MODULE LOCATION
Sable, Taurus & Windstar......Right Rear Of Engine Compartment, Mounted On Cowl
RETRIEVING CODES
Fault codes are retrieved from EEC-V system through Data Link Connector (DLC). Self-diagnostic test procedures are for use with Rotunda Worldwide Diagnostic System (WDS), New Generation Star (NGS) scan tool or equivalent. If a generic scan tool is used, ensure scan tool is certified to OBD-II standard.
DATA LINK CONNECTOR LOCATIONS
All Models......Below Instrument Panel, Right Of Steering Wheel
(It may have a plastic cover clipped over it)
Apr 22, 2009 at 10:28 PM
GATEKEEPER
  • 6 POSTS
thanks guys, appreciate all your help
Apr 23, 2009 at 6:45 AM
