2003 Ford Windstar O2 sensor
120,000 MILES • 6 CYL • FWD • AUTOMATIC
HANDYMAN5421
check engin light came on i used OBD2 code scanner code 136 O2 sensor shot had it replaced two weeks ago check engin light back on code 136 back went back to shop mechanics says i should have changed both is this true?
Jan 19, 2009 at 8:04 AM
BMRFIXIT
  • 19,053 POSTS
you do not have two replace two
its beter if you do
Possible causes are :
Damaged wiring harness or Connector
crossed sensor wires
exhaust system leaks
faulty o2 sensor
good luck
Jan 19, 2009 at 8:55 AM
