2003 Ford Windstar no heat in front or back of car
134,675 MILES • 6 CYL • 2WD • AUTOMATIC
STKING007
the car heats up but there is no heat blowing in the front or back. there is no clicking sounds coming from the dash area. the temperature guage rises from cold to half way to hot normally. doesn't seem like an acuator problem. just not sure what it could be. maybe the thermostat? when i switch from cold to hot there is a difference in blower force. it is slight but i can see there is a difference. thanks for your help....scott
Oct 9, 2010 at 1:29 AM
  • 110,246 POSTS
With the engine running, warm, and the heater on, are both heater core hoses getting hot? Try replacing the thermostat and check the heater core if its clogged, also check the blend door might be stuck in the cold position and also the heater control valve
Dec 20, 2016 at 10:08 AM
