Blower motor replacement
2003 FORD WINDSTAR
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
B1MZBM25
No noise coming from the blower motor what is wrong?
Apr 24, 2010 at 12:31 AM
SQM
  • 6,383 POSTS
There are few reasons for the blower motor not to turn on.
You could have a bad motor, faulty relay, faulty resistor or a wiring issue.
First thing should be checked is the blower motor relay.
Make sure the relay is functional.
Here is how to test the relay:
If the relay is good then the next item to check would be the blower motor.
https://www.2carpros.com/articles/blower-fan-motor-works-on-high-speed-only
I have attached the blower motor replacement instructions for your reference. Also included the fuse block diagram, that shows the relay location.
Aug 1, 2021 at 7:20 AM
